RE: How to install a kill switch in a 6ch setup that uses already a dual elevator???
I guess I didn't make my post clear. No need to buy a reversed servo. You can simply reverse the servo arm (remove and rotate the arm 180 deg.) on one of the servos. Sometimes the geometry is OK, but, to do it correctly, you must have the center of each arm and the control horn in the same horizontal plane. Good luck, red
