RCU Forums - View Single Post - Kill Switch for a Glo Engine
Old 05-29-2012 | 06:37 AM
scale only 4 me's Avatar
scale only 4 me
My Feedback: (158)
Default RE: Kill Switch for a Glo Engine
ORIGINAL: BarracudaHockey
ORIGINAL: carrellh
Failsafe works if the signal between the transmitter and receiver is lost.
If the receiver battery, onboard switch, or receiver fails; the failsafe will not work. Of course kill switches will not work in those situations either.
Optical kills shut down the ignition if they loose power, or loose signal.
Without going on and on off topic,, Andy that is true,, that is how the optikills are designed to work,, But it depends on the Failsafe programing weather it works or not.. If the Failsafe is set to "Hold" it will hold the ign in the on position on signal loss.
