RCU Forums - View Single Post - rubber bands for wing hold
Old 05-29-2012 | 01:17 PM
CGRetired's Avatar
CGRetired
Default RE: rubber bands for wing hold
Not exactly. There still has to be enough "stock" to cut threads into.
Obviously, you can't drill and tap soft woods - pine, balsa, redwood, and so on.
The best suggestion is to treat the drilled hole with thin CA before and after passing the tap through the hole in hardwood. Hardwood will take a properly sized drill without gouging, when done carefully.
CGr.
