RCU Forums - View Single Post - Powerbox Cockpit SRS Problems
Old 05-29-2012 | 01:20 PM
Aussie Bart's Avatar
Aussie Bart
Default RE: Powerbox Cockpit SRS Problems
George
<p class="MsoNormal"><span style="font-size: 9pt; line-height: 115%; font-family: Arial, sans-serif; background-color: white; background-position: initial initial; background-repeat: initial initial; ">The people at Powerbox refuse to accept that there could be a problem, read my original post's in this thread - you know, the one's you bagged.... I pointed out then that there was a glitch in the system and all Powerbox would say is that I had plugged my lead in incorrectly. They then proceeded to contradict themselves in emails which just proved that they had no reasoning as to the failure.</span><span style="font-size: 9pt; line-height: 115%; font-family: Arial, sans-serif; ">
<span style="background:white">The simple question was "How can the receiver regulator work when selected as spectrum but not work when selected as Futaba/Multiplex/Jeti" ?????</span>
<span style="background:white">I understand that if they admit a fault then many users worldwide will dump the product, however a decent manufacturer would at least ask for the unit back on the quiet just to try and establish if there was an issue with them.<span class="apple-converted-space"></span></span>
This is the same product that did not operate the sequencer if only one battery was switched on but allowed all other functions; I struggle to understand the benefit of writing software on purpose to do this.
<span style="background:white">I remember another manufacturer who when things went wrong simply blamed everybody who used their product of incompetence, their name was XPS.</span>
<span style="background:white">Like Craig, I too used many Powerbox products with success but found strange happenings with the Cockpit unit, and when I did ask Powerbox direct I was treated like an idiot, much like the closed mind attitude you display in this forum.</span>
<span style="background:white">All Powerbox are doing with this type of attitude is encouraging people to look at the other products on the market, and having recently used the Futaba/Robbe SBus system in my Cougar and having found it to be far nicer than the Powerbox system I will now replace the cockpit units in my Tucano and F4.<o></o></span></span></p><p class="MsoNormal"><span style="font-size: 9pt; line-height: 115%; font-family: Arial, sans-serif; background-color: white; background-position: initial initial; background-repeat: initial initial; ">I accept that you don&rsquo;t have direct issues or have not had any reported to you by your customers but to simply express that it is not possible and that we are endangering people or property by using the product is naive, what is the use of just plugging another unit in if it still has the same software, at least XPS would come out and say that they were offering software updates........</span></p>
