RCU Forums - View Single Post - Tiny-X is built!
Old 09-04-2003 | 01:53 PM
Arrow>>-->
Default Tiny-X is built!
I think you would be a little happier if you got the Eps-300 Slow stick rather than the 100 just for the fact that you will:
a. Have a little better control of it in any wind.
b. Once you get the hang of it be able to do much more with the plane like loops, rolls, and my son's favorite as he calls the switllies ( controled spin).
If you go with the 300 you would probably want the ICS 300 or 400 which would still work on your Tiny.
You will also want a bigger batterry pack. The 350 mah will only give you 3 or 4 minute flights. Get either some 700 mah AAA's or even better some 1800 mah AA's. That is what we are using on the slow stick and getting 20 plus minute flights. Another good battery choice are Kan 1050's.
The Slow Stick should be available at any Hobby Store around you for around $35.00. Lot of threads on the SS on setting it up and flying it so good luck. By the way saw your pics of the Tiny. Great job on the covering. Like was said in another post you may want to add some graphics or a bit more red to one side of the wing so orietation is easier.
