RE: Powerbox Cockpit SRS Problems
Sicliclk, just test it, the first one I had I put into F14 , i have them in two cougars , one in An A10 also A Comp arf P47 and not a single problem,
yes I have seen one pluged in wrong and PUFF the magic dragon or Tich as it goes when its pluged in wrong , came in to play, but really they are the best on the market, In india yes, Ragz did look at the frame counter and did,nt reset it to normal screen ,so the sequencer didnt work I knew about this and said to Ragz during the flight.
Also if a battery fails to turn on because of switch or bad battery conection or some other problem , sequencer will not work, it is a warning to look at things. Powerbox-systems leave nothing untested they are very good at what they do, I have total trust in the systems they develop, If you use a large number of channels and want redundancy this is the best.... opps here we go.
