RCU Forums - View Single Post - How to install a kill switch in a 6ch setup that uses already a dual elevator???
Old 05-30-2012 | 05:54 AM
Charlie P.'s Avatar
Charlie P.
Default RE: How to install a kill switch in a 6ch setup that uses already a dual elevator???
ORIGINAL: matador_24
ORIGINAL: coralcape
I guess I didn't make my post clear. No need to buy a reversed servo. You can simply reverse the servo arm (remove and rotate the arm 180 deg.) on one of the servos. Sometimes the geometry is OK, but, to do it correctly, you must have the center of each arm and the control horn in the same horizontal plane. Good luck, red
Hello, thanks... I understood the idea but if i do so, the servo arm will not be levelled with the elevator anymore, actually it would be to inclined... I would have to move the servo upper in the fuselage and I am not sure I would like to do that..... I hope I understood what you meant.... thanks for your idea!
Or flipthe servoend-for-end in the same cut-out and shorten or lengthen the control rod.
