RE: BIG LAMA
Thanks, I'll check it out, I highly doubt the motor is bad or inner shaft is bent. I have a total of about 5 flights w/no major crashes, and I just installed the xtreme inner shaft, so unless it came bent it's not bent. The verticle shakemay just be a result of me stuffing the tail w/foam, but again it'ssimply a "cosmetic" shake, I'm still able to hover perfectly still, the tail just vibrates up and down, but the last time I poweredup in the garage the shake went away, so I don't know what to make of it, maybe I'll just ignore it becauseonce the chopper is ten feet away and in flightyou can't tell anyway...
