ORIGINAL: mick15
This is a copy of the email I received when I asked the factory the same question.
''Hello,
can you have a look to the software version of your Cockpit? Newer Versions show the Version when you turn on the PowerBox on the right side of the Logo.
Older Version:
Turn on the PowerBox. Disconnect the batteries. Hold Button I&II and connect one battery. If you have a version 03 or higher you will have no problem with the sequencer. This issue is solved since May 2011- some days after bringing the PowerBox Cockpit to the market. The guy in the forum seems to have very old versions- one of the first. I´m wondering because we informed our customers…
The thing with the Power off the receiver was a customers fault. He connected his Futaba receivers wrong. Newer Powerboxes have fuses inside, so also mistakes done by customer will not short the Powerbox out.''
ok guys, I followed the above instructions (for the older version as the version number did not display as described above for the newer version) and here is what displayed......
Am I correct in understanding that I have version "02" here? If so that would explain my sequencer failure, but it would not explain the fact that this is a unit that was shipped to me only recently to replace my previously failed unit!!! [:@]
