RCU Forums - View Single Post - Ryobi Conversions
Old 04-28-2002 | 01:44 PM
kevin mcgrath
Default Ryobi Conversions
Not sure what you mean,but if you are referring to the carb being buried in the cowl behind the engine and air intake to it,its not a problem IME.
Keep in mind many of our most powerful designed for purpose engines (ex,,,ZDZ,3W,DA) are set up the same way.A "cold" air intake is easy to arrange....if its needed.
I just put a tape on a Ryobi in my shop and it measures 6.5" from the rear of the carb to the front of the prop driver,with a Bisson muffler in place,with the B&B mount adding maybe 1/4" more.. For comparison A 38 cc Quadra 400,(which uses a side mount carb and muffler) in my 1/3 Spacewalker with a bell mount measures exactly the same at 6.5".
