RE: Lipo Fires Are Real![Fantastic Advice!] Can I ask for further help?
i may one day regret this but i dount use any thing no sack no box to store them in,some stay in the cars there in, radios , and i have a few just around,i dount use a expensive top of the line charger,my chargers are thunder ac6 55.00 shipped and a thunder t6 multi was a bit higher i have not had a battery catch on fire,and i have also had them get below 3v cell and use my nimth seting to bring them back to life, only thing i do is tern on my charger set the number of cells,voltage and if its a 2.2 i charge at 2.1 amp each setting to its own battery,witch nither of my chargers will let you just hook up a battery up or start untill there right,and if you hook it up backwards it will let you know very fast thats not right,so im not sure my advice is what you need but dount be to over protective,
