RE: Lipo Fires Are Real![Fantastic Advice!] Can I ask for further help?
your right what i do may not be good for others,its funny i worry more about charging my nicd and nimth battery's i have had them to catch fire and if you ever seen or had a nimth battery pop it will shake you a bit, it not only has hot stuff coming out it has shrapnel as well, we all take a risk to run a rc,some like me just take a bigger risk,i also use the liion battery's with same manner,to me it must be the way these batterys are done,if i do them like this as i stated before and have no problems, a little care will help keep you in the safe, best thing is get a lipo and charger and keep them in a way that makes you feel safe, that should be some better advice, thanks
