That's great news. I missed that reading the manual. Thanks very much.
ORIGINAL: Richi-d
Hi Guys,
you can enable the Digital output. Then on Elevator B and Rudder you get a S-Bus output. It can be used to go into a SRS PowerBox, but you can also use it for S-Bus application. The channels you select for control surfaces in the "Input Maping" Menue are then with gyro signal on the output
