RE: evolution 50 cc gas engine troubles
Check how you have your ignition module mounted. They all seem to require an air gap. If it is mounted flush to the motor box, (or wrapped 100% with foam) the ignition may be overheating causing the cutting out.
I have heard this from other pilots and have taken the time to mount the module on my DLA-32 with a 1/4" air gap and made a vibration isolating mount.
