RE: Probat mystic 29
put the batteries where they are suppose to go, set your strut the recommended hight and make sure you don't give it any positive angle.
lowering or raising the strut will adjust how wet or loose the hull is, prop angle will push the nose up or down.
you most likely have to much positive.
Dan.
