RCU Forums - View Single Post - redudant rx setup problem
Old 06-05-2012 | 09:39 AM
Portlandflyer
Default RE: redudant rx setup problem
<p class="MsoNormal" style="margin: 0in 0in 0pt"><font size="3" face="Times New Roman">First off, 6 volts is perfectly fine for newer version servos.</font>
<font size="3"><font face="Times New Roman">
Something is not right for sure. My guess is even though both controllers are set at 6 volts, the Fromeco voltage is lower than the Digiswtch so the 800ma pack is not being drawn from (or very little). There is nothing wrong with this. What will happen is you will draw from the 1000 ma pack and only when the voltage drops to the Fromeco voltage; you won&rsquo;t see any draw on the 800 pack. <span style="mso-spacerun: yes"></span></font></font></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><font size="3" face="Times New Roman">
My question is why such a large draw on the 100 ma pack? I&rsquo;m assuming you are running this in a 2 meter plane with normal size servos. I draw about 40 to 50 ma for a 7 minute flight. You might try setting the Fromeco a hair higher voltage from the Digiswitch to have the receiver draw from the 800 pack to see how much it draws.
One more thing, the size of your packs are way over kill. You are just adding extra weight. I run two 350 TP packs with two Tech Aero controllers and can get an easy eight flights.</font></p>
