JR9303 issue
I was setting up the ailerons on my MXS-R with my 9303 to use 2 different channels. I needed to turn down the travel to fit the recommended throws for precision aerobatics as opposed to 3-D. I was in the travel adjustment menu and selected the aileron channel. It let me adjust the "left" throw, then the right. I went into the servo reverse menu to get everything going in the right direction, and now the travel adjustment won't let me select "right" throw at all. It flashes and goes back to left throw even with me holding the stick all the way to the right. What's up? I just got the radio back from horizon where they put a new motherboard in it. Haven't used it but maybe 3 or 4 times. Never had this kind of issue before. I always consider that I'm doing something wrong before I assume the radio is the issue. Let me know what you think.
Steve
