ORIGINAL: cbooth1979
Hi,
Thanks for the reply! Thats good to know, I assume 3500-4500mAh would be good as well for a day of flying?
Thanks again,
-Carl
2300mah should be good for a least 4 flights and you can recharge them in just 15 or 20 minutes. FYI, switching to A123 may require an adjustment to the glow plug voltage to keep from blowing them. Unfortunately, it's not easy to do. Requires a program and an adapter to hook up the ECU to a computer.
Craig
