RCU Forums - View Single Post - redudant rx setup problem
Old 06-07-2012 | 07:31 AM
Silent-AV8R's Avatar
Silent-AV8R
Default RE: redudant rx setup problem
Well, that is different from your first post. In that case I think you are seeing the effects of how the two different regulators are allowing the load to be distributed between the two equal packs. Typically I would use the same equipment for both packs to eliminate this type of situation.
