RCU Forums - View Single Post - redudant rx setup problem
Old 06-07-2012 | 08:20 AM
Portlandflyer
Default RE: redudant rx setup problem
<span lang="EN">
So I posed this question to Ed at Tech Aero:</p>
I am currently running dual Tech Aero controllers (one switch) and 350 ma packs. I have the voltage set to 6 volts on both. Each pack is drawn down pretty much the same.</p>
My question is, if I leave one 350 on one controller, but use a much larger pack (1,000 ma) on the second controller will the draw be the same on both packs (50% from each pack) or will the draw be greater from one of the packs? In other words, do the controllers draw equal amount?</p>
This is his response:</p>
Changing the capacity of the pack isn&rsquo;t going to change the amount drawn from each, so the smaller capacity pack is going to need to be recharged sooner than the higher capacity pack.</p>
So, at least for Tech Aero units, they indeed do isolate the batteries from the receiver and will draw the same amount from each battery.</p></span>
