RE: How to install a kill switch in a 6ch setup that uses already a dual elevator???
Hello,
Finally I got the hitec programmer console. It was very easy to invert the rotation of servos and then problem solved! I just added a normal Y harness and now I do not need an extra channel for it... I left the kill switch in the gear channel.
By the way.... about the issue I had about the travel limits in one of the servos... I connected both servos and stranged but one of them didn't have the center point in the same point than the other! that is why the travel was different! I restored to 'original settings' and the problem is gone!.... weird because I had NEVER used any console to program the digital servos.... no idea.... anyway, it is solved!.... I think the console is a nice tool for $ 40....
Thanks for all the help!
