ORIGINAL: rcjetsaok
Guys,
The ECU will handle 7.2 to 14.0 volts... There is no setting anything... The ECU will only send the correct voltage to the pump and glow plug regardless what the input voltage is !! Ya'll are worrying about nothing... Plug it, go fly !!!!
Danno
I hope your right Danno but I was definately blowing plugs when I switched to an A123 battery with my Pegasus (ECU Version 2). It may have more to do with differences in resistance than total voltage. Attached is the info sheet from AMT addressing the issue and recommend ECU settings.
Craig
