RE: Is it my ignition or engine?
Hi
Quote : if youdo not hold the buggy down you will lift it right off the ground, and it weighs at least 20lbs.
This engine doesn,t have a 20 inch prop ,............................. it has a 1/2 inch spool . You can not compair this two .
Do what has been suggested to you .
CHANGE THE IGNITION
Michel
