RE: wire and connections adding to heat creation
There is no question that too small connectors can cause heat failures as well as robbing you of top speed. I use 8mm connectors on any 5000mah and above lipos, and am changing (from inefficient Deans) to xl60 for smaller batteries. If your connectors are getting hot, you're not getting all the power available.
