As I told earlier, after sanding with 240 grit sand paper, I polished fuselage with 800 water sand paper...
After cleaning I start putting rivets and details on fuselage...
Engine mount and spacers are finish also...
For now I made it from 5mm steel plate, because my opinion is P 47 will need weight in front. If not need weight for CG, I will made that plate from aluminum...
Regards
Mirce
