RE: Panther Camo Question
Glen<div>Yes that is a form of the ambush pattern, I had once thought the ambush pattern was used on the western front but apparently it was used on both fronts. I have found many 5th SS pics with the ambush on it as well as quite a few stugs in the east.</div><div>
</div><div>that disc pattern is real easy to make using a standard hole punch</div><div>
</div><div>you can buy rub off decals from Aber to create it as well. After the discs were applied they sprayed a random stretch of base color allowing the edges to feather out with spatter from the airbrush.</div><div>I just did it on my panther, the camo pattern really works but alas I didn't like it so I sanded and repainted.</div>
