RCU Forums - View Single Post - ys 91 ac question
Old 06-10-2012 | 10:29 AM
Four Stroker
Default RE: ys 91 ac question
Well Alberto;
You are not getting a lot of help here. You say the engine has good compression. Do you have good tank pressure ? Should be about 6 psi.
Old Dave Shadel once said that the main culprit of air chamber engines was air leaks around the chamber. This would include the gasket and O-rings on the transfer tube. Are you spewing fuel around the chamber instead of out of the carb ?
