Props
What a great topic! Wish I had a great answer, but I don't. What ever works, works, keeping in mind a few things. A prop is nothing less than an airfoil and any alterations to the geometry or weight of one blade or the other will change the effects, for better or worse. With that said, a prop must be in balance, thus the dilemma of how to do it. In my years of modeling, I've not discovered the perfect way to balance a prop. Anything I've been told or tried myself has always been a compromise to the geometry of the blades. You may get the prop balanced by sanding this or that, only to have changed the tone of the prop, where one side is pulling harder than the other. This can cause a different vibration all together. I like the balancing by paint or finish technique that Fred has described. This seems to me to be a method where one would at least keep to a minimum, blade distortion. This is an area where the manufactures could really make some improvements. I've bought props that were so out of balance that they were unusable, primarily in the wood prop department. Yes, a major manufacturer made them. More times than not, it is because the hole was not drilled to center. Wouldn't it be great if a manufacturer marketed props that were guaranteed to be in balance? I'd pay a few extra bucks. Happy Flying!
