RCU Forums - View Single Post - THE FIELD BOX FROM HELL! aka The Ultimate Field box!
Old 06-11-2012 | 06:18 AM
  #585
jsevey
Default RE: THE FIELD BOX FROM HELL! aka The Ultimate Field box!
I used a new blade in a utility knife. Drill holes at each corner to run the cut into. You can also use a dremel with a cut off wheel but you will get melted plastic that has to be cleaned up.<div>
</div><div>jim</div>
