RCU Forums - View Single Post - Meister Scale P 47 - step by step
Old 06-11-2012 | 01:20 PM
  #437
mirce
Default RE: Meister Scale P 47 - step by step
Today I get engine plate and spacers. For now I made plate from 5 mm steel plate. I'll see if I need to add weight for CG steel will be OK. If not I'll made plate from aluminum...
I want to thanks to my friend Dragan, who made all this parts.
Engine plate have 6 spacers...
Four spacers are made for engine...
All together it look like this...
I'm inpatient to fix engine on fuselage, but on my working table is Ziroli P 38.
Today I was sanding leading edges, and tomorrow, when finish that job, I will put engine on P 47...
Can't wait to see how it will look...
Now I have question for you guys, when you put engine on fuselage on Meister P 47, are you made angle to right and down?
On Top Gun some told me that they wasn't do that.
I always put those angles, but I want to ask...
And finally, some small work on cowl...
Cowl was sand with 800 grit water sand paper, and primed...
Regards
Mirce
