ORIGINAL: jsevey
I used a new blade in a utility knife. Drill holes at each corner to run the cut into. You can also use a dremel with a cut off wheel but you will get melted plastic that has to be cleaned up.<div></div><div>jim</div>
Thank you Jim!
<br type="_moz" />
