RE: Best method to remove old EconoKote film?
I find that the easiest method to remove any kind of film
covering is with my Top Flite heat gun, find a seam or corner
hit it breifly with the heat, grab the edge of the film and heat as
you pull up at a 90 degree angle, leaves very little residue. To
remove any remaining residue, use a putty knife to gently scape as
you apply heat from heat gun. I have used this method on all
brands of plastic coverings with great sucess.
Bill D.
