RE: wire and connections adding to heat creation
SRT10 is right, resistance is highest where the heat develops.
If the soldering is whats getting hot, the wires isn't your problem.
And neither is the connectors.
Its the solder itself.
If you haven't had the same experiences sundog, then just do some proper solders and test again.
Or just do the maths.
