RE: Brake????
Brakes are a Pressure Active function and almost zero flow, restrictors will do little to help.
If you run a seperate air tank for the brakes, only pump it up enough to stop them locking, else use a proportional pressure control valve like the BVM smoothstop or Jetronics electronic proportional valve.
