RE: us41 in byron p51
I have had a number of these over the years, I always use a starter with 24 volts and someone with their finger in the carb to choke it. The ones you probably saw on you tube were changed to electronic ignition
instead of magnito. You will be flipping by hand till your arm is sore and it probably will not start and run.
bob
