RE: wire and connections adding to heat creation
Well, as proven by common sense, and now also by maths, having connectors with a cross section larger than the wire itself doesn't make much sense.
So unless you got 50.26mm² (that is 1 AWG) wires, then 8mm bullett is overkill.
