Com Cutting!!!!
You can get a good lathe and carbide bit for about 150$. If you are just bashing, I would clean the com with a com stick avery 4 runs or so and cut it when it starts to get grooves in it that the stick won't take out. Unless you are trying to get max HP you really don't need to cut it unless it needs to be trued.
