ORIGINAL: giddyuperic
Thank you very much. So do you know if the line I would like to rig her with should be 1.1mm will that be okay? Thank you for your time
I really haven't measured the diameter of the line I use. I go by the "test" as in 30 pound fishing line or 30 pound test. Whatever you select the line should not stretch - a good product is Spectra fishing line, for this very reason. The line has to be flexible enough to work with the "bowsies" your boat came with.
The line has to fit through the guides without binding and shouldn't be cotton as it absorbs water and is stretches quite a bit. I'll have to get my micrometer to find out what diameters I am using.
