RCU Forums - View Single Post - wire and connections adding to heat creation
Old 06-14-2012 | 09:12 AM
Goldenduff
Default RE: wire and connections adding to heat creation
No don't go in a huff Von Bain!<div>
</div><div>It is well known that the real world and theory are different. I'm not taking sides, I believe the Mathis is correct however in practice would larger connectors permit more solder thereby in increasing the area and compensating for its relatively higher resistance?</div>
