RE: Phoenix Decathlon arf CG
I was always under the impression you balanced a high wing right side up and a low wing upside down, but probably can be done either way. As to the Decathlon, I had that plane and you want about 90mm from the leading edge; manual was 100mm and that makes it a little tail heavy and snap happy! There's a pretty good thread in this forum about the plane...
