RE: RCV Engines
I had bought an RCV 58 CD, few years back direct from RCV and it was stored preserved with oil. Recently I started to run it in before mounting it on a model. The model was stored with 2stroke engine oil (as recommended by Laser Engines and flushed off before being run in). The engine starts fine.
I am using 18% all synth (Klotz) and 5% nitro fuel. Running in is on a 12x6 APC prop
Even while running in the engine at recommended 6000 RPM the bottom of the case gets very hot, so much so that you can not put your finger on it. My experience with other engines has been that if the engine is running well the case bottom remains cool where you can keep your finger (only after shutting the engine down does the case bottom temp goes up).
The question for all RCV owners/runners is this normal with RCV? I have about 45 minutes of run time on the engine now and entire running was below 6000 RPM
Appreciate any help or pointers
