Help! front seal?
I have a rjl 61 engine that I just got done replacing the bearings and crankshaft in. I just started it up and I have oil running out of the front bearing. There was a very small leak out of the front seal before I changed the bearing but now it is literally running out as the engine is running. It is a rubber seal bearing from rcbearings and the bearing looked fine when I put it in. What would cause the fuel to run out of the front bearing? I am going to disassemble it now and see if everything looks good. Any body know if this is an obvious problem?
