RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 06-17-2012 | 06:12 PM
  #405
slskn
Default RE: UMS Evolution Radial Care and Operation
ORIGINAL: Orion09
http://www.youtube.com/watch?v=I5O5uBxPl0A Got the first and second flight in.Had some flutter on the elevator but landed safely.Engine runs great. Pete
LOOKS GREAT Pete, looks like plenty of power, and sounds great.
well, I took out my Corsair out a few days ago and could not get it to run properly, right after I did two things, I adjusted the valves and used the correct fuel, and l could not get it to run over half throttle, so home I went and tried to change back to the old fuel that I was running before, and still no luck, then realized the only thing next was to check out the valve adjusting, then I realized I had used the wrong feelers gauge thinking that these are the ones I use on my other 4 stroke engines, which are 0.040- to 0.010, so back to the manuel and seen the correct .004- to .006, so I plan on getting the correct gauges tomorrow and re-lash those valves again and hope fully get them right and hopefully run a lot better this week, if it works I will be tickled pink again- Steve
