RE: Byron p51 engine conversion
Another note. The fiberglass is a polyester resin so be careful what you use as a glue. Not all glues will stick well. I've used Hysol epoxy and that works well. Expensive but it does adhere. Or you can glass the plywood to the fiberglass with resin. Also, make sure you clean and lightly sand/scuff up the glass well.
