RCU Forums - View Single Post - Servos for SFHSS
Old 06-18-2012 | 12:03 PM
ronwc's Avatar
ronwc
My Feedback: (404)
Default RE: Servos for SFHSS
ORIGINAL: Bax
This is being way over thought. You can use ANY regular servo, digital or analog with that receiver. When we say ''that receiver'', that means receiver. Mode is irrelevant. If we were going to mention a mode, we would have.
The R2008SB receiver operates on FHSS mode when an FHSS transmitter is present, and S-FHSS mode when an S-FHSS transmitter is present. It does not ''care'' which servos you use. However, you MUST use S-Bus servos on the S-Bus, or an S-Bus decoder when you use other servos.
Again, we don't know where the idea came from that FHSS and SFHSS affected the servos.
Where the thought came from is that S-FHSS is suppose to be high speed mode (I thought) and most sources say you cannot run analog servos in high speed mode - you have to use digital or you can burn up servos. Is S-FHSS high speed mode, and if it is ok to use all the time with all servos, then what is the FHSS setting used for.
