ORIGINAL: llindsey1965
wow another dle crazy, my DA runs circles around the junk china engine if yours doesnt you have it set up wrong , china is nothing but junk their steel is sorry grade their bearings suck , DA uses all top quality parts my da 50R has 80 gallons of fuel thru it and has been on 2 different planes, no problems after every run i run marvel mystery oil thru my carb and into my motors DA is the best engine on the market , if you cant afford one dont try to knock expensive engines DA is all i will use they have a great track record , great warranty , great service and they are made in the good ole USA so send your money to china if you want but i choose to keep mine in th
what kind of rpm's do you get on your DA50 with a xoar 23-8 or even a xoar 22-8? is it on a pipe or canister or just stock side dump muffler?
