Thanks for the response. I'll definitely check those out.
Newb Question - Is there any stock tweaks I should make sure to do that will make the stock set up run better? ie. Best spring rate, any ESC settings, etc etc that I should adjust for best all round performance and safety (for vehicle, not human/physical). Im mostly on sandy pavement, short grass and only smaller jumps etc....no serious "bashing" etc.
Also,, anything I should check for? I simple unpackaged it, charged'er up and ran it. Not sure if I should ensure I'm setting this or that, and checking this or that. (keeping my eye on all screws and so far so good. Also have blue locktite laying around just in case)
edit - also from what i think i read in this thread, its the "mah" in the batter that determins (so to speak) run time. SO for instance would this:
http://hobbyking.com/hobbycity/store...dProduct=14991 have more run time per charge than this:
http://www.hobbypartz.com/77p-sl4400-2s1p-30c-2222.html ?? Planning on keeping at 7.4 volt for now.
Thanks again everyone.
