RE: AMR High Wing Stick 30
I have all the servo's for the control surfaces installed and servo leads. The Robart hinges have been epoxied into the stationary side. I will let these cure until tomorrow then glue the control surfaces on. Once this has cured I can build all the linkages. It looks like I will be able to install the fuel tank at the CG. I will have to wait until the linkages are installed and start moving the batteries around for balance and see where everything winds up.
Later!!
Anthony
