RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Why about where the engine screwed down to? That has to be tightens up pretty tight so the motor wouldn't move around.
I was so close of doing it but all these conserns came to mind. When I was gonnado it I was not making any holes but for the flywheel. When I grabed the 3mm material and twisted it it will flex a bit do left me wondering if I should use 4mm.
Well let us know how it works out and bi the way you might have to add weight to the front do your tires can get some grip. So this is the cool part about weight reduction you now can add weight to where you want now.
