RCU Forums - View Single Post - Byron p51 engine conversion
Old 06-19-2012 | 09:26 AM
Check6
My Feedback: (427)
Default RE: Byron p51 engine conversion
Hello Comanche 260,
This is an easy fix. You don't need the Byron mount setup. I have done numerous conversion like this. I epoxy in a new firewall adjusting the depth to fit the engine mount setup. If you have a problem I will do it for you. I put in a 1/2 plywood firewall glassed and reinforced in the new position using the proper adhesive. I'm in Rhode Island, I notice you are in NY, probably not too far from me. Let me know . Any questions give me a call 401 934 0921.
Fred Menna Check6
